Breville BKC600XL On/Off Switch Replacement
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL On/Off Switch Replacement, Power Cord: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
Antonio
crwdns2935283:009/26/12crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-3, Propen Fall 2012 crwdns2935289:0Cal Poly, Team 1-3, Propen Fall 2012crwdne2935289:0
CPSU-PROPEN-F12S1G3
crwdns2935297:018crwdne2935297:0
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - crwdns2934203:0crwdne2934203:0
This repair worked like a charm! Boyd Gilberts part number link was perfect....coffee machine is running great once again.
anthonypetric112 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,943
