Breville BKC600XL Heating Tank Replacement
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Power Cord: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Breville BKC600XL Heating Tank Replacement, Clear Hose: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Antonio
crwdns2935283:009/26/12crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-3, Propen Fall 2012 crwdns2935289:0Cal Poly, Team 1-3, Propen Fall 2012crwdne2935289:0
CPSU-PROPEN-F12S1G3
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 4,747
