Brentwood TS-292B Heating Wire Replacement
  1. Brentwood TS-292B Heating Wire Replacement, Heating Wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood TS-292B Heating Wire Replacement, Heating Wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five screws to loosen the the outer housing from the internal components.
    • Pull up on the black plastic housing until it is dislodged from the base.
  2. Brentwood TS-292B Heating Wire Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brentwood TS-292B Heating Wire Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brentwood TS-292B Heating Wire Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will need to remove the toasting lever by removing the black tab from the lever.
    • You will now be able to completely remove the housing from the base of the toaster.
    • You will need small chain nose pliers to check for slack on either end of the broken wire.
    • If there is no slack in the wire, you must buy extra nichrome wire in order to fix your toaster.
  3. Brentwood TS-292B Heating Wire Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the slack out of the wire and pinch the two ends of the wire together.
    • Gently twist the two ends of the wires together to establish a connection.
    • Disclaimer: The wires are flat so you will require extra wire if you are not able to obtain enough slack.
Elly Ayala
crwdns2935283:009/21/18crwdne2935283:0
739 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S8-G7, Riccardelli Fall 2018 crwdns2935289:0University of North Texas, Team S8-G7, Riccardelli Fall 2018crwdne2935289:0
UNT-RICCARDELLI-F18S8G7
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 144
