This guide will show how to remove and replace the nichrome wire (heating wire) of the Brentwood TS-292B.
Remove the five screws to loosen the the outer housing from the internal components.
Pull up on the black plastic housing until it is dislodged from the base.
You will need to remove the toasting lever by removing the black tab from the lever.
You will now be able to completely remove the housing from the base of the toaster.
You will need small chain nose pliers to check for slack on either end of the broken wire.
If there is no slack in the wire, you must buy extra nichrome wire in order to fix your toaster.
Pull the slack out of the wire and pinch the two ends of the wire together.
Gently twist the two ends of the wires together to establish a connection.
