This guide will show how to remove and replace the browning dial/circuit of the Brentwood TS-292B.
            Remove the five screws indicated using a Philips head screwdriver.
            Pull hard on the browning lever until it detaches from the toaster.
            It will take some force to pull it off.
            Once the tab is off, lift up on the housing to remove it from the toaster.
            Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
            There are four screws on the circuit board for the browning dial.
            Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
            There are two holes on the board where the pin from the browning dial can align.
            Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
            Replace the entire circuit board if need be.
