Brentwood Animal Shape Waffle Maker TS-253 Disassembly
  1. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove Plastic Piece Covering the Power Supply: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove Plastic Piece Covering the Power Supply: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the waffle iron so the bottom is facing you.
    • Remove the four corner 10 mm screws from the plastic covering using a Phillips #1 screwdriver.
    • Remove the plastic covering.
  2. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove connector screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove connector screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove connector screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5 mm screws that hold the red and blue circuit wires in place using a Phillips #1 screwdriver.
  3. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Detach Waffle Iron from Plastic Covering: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Detach Waffle Iron from Plastic Covering: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The safety heat protector is not shown in this image.
    • Open the waffle iron.
    • Remove the four 10 mm screws holding the iron and plastic together in the corners of the iron with a Phillips #1 screwdriver.
  4. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Detach Heat Safety Feature from top iron: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The plastic covering is not supposed to be fully removed and will be stuck in the wires. For the purpose of demonstration, we have cut the protector off for better visuals. DO NOT not fully remove heat safety features as demonstrated; only unscrew the connecting screws and be gentle to not break the heat safety element.
    • Detach the safety heat protector located on top of the upper side of the iron by removing two 5 mm screws using a Phillips #1 screwdriver.
    • Detach the red and green LED light covers by gently pulling them off the ends of the wires.
    • Missing image
  5. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Detach thermostat: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the thermostat located on the upper half of the iron by removing two 10 mm screws using a Phillips #1 screwdriver.
  6. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Repeat Step 3 for Bottom Iron: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Repeat Step 3 for Bottom Iron: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat Step 3 for the bottom iron.
    • Remove the four 10 mm screws in the corners of the iron with a Phillips #1 screwdriver.
  7. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Remove Heat Safety Feature for bottom iron: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once again the following pictures will not have the safety features shown because we fully removed it.
    • DO NOT cut your heat safety feature off; you will not be able to put it back.
    • Detach the safety heat protector located on bottom of the lower side of the iron by removing two 5 mm screws using a Phillips #1 screwdriver.
  8. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Pull Wires Out from Bottom Plastic Covering: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, Pull Wires Out from Bottom Plastic Covering: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wires from the bottom plastic covering by gently pulling them through the hole in the plastic towards their connections to the waffle irons.
    • Remove the bottom plastic covering.
  9. Brentwood Animal Shape Waffle Maker TS-253 Disassembly, You're Finished!: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Brentwood Animal Shape Waffle Maker TS-253 Disassembly, You're Finished!: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Final disassembled product!
To reassemble your device, follow these instructions in reverse order. Make sure to not rip or break heat safety elements once broken or fully removed they cannot be fixed.
Sam Goldberg
crwdns2935283:009/14/22crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 102
