Bravilor Bonamat THa Err 11
  1. Bravilor Bonamat THa Err 11, Disconnect power: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the power cord before opening up anything. Double check that correct powercord is disconnected! This procedure is not possible without getting close or even touching the power mains connectors inside.
    • If you can't get access to the back panel without disconnecting the water hose, ensure that water is disconncted before taking off the water hose. It's bad to not having coffee, but having your kitchen area hosed down in water does not help.
    • Remove the two T15 torx as shown in the picture. A flat head 4 bit can also be used.
    • Pull the back panel out from the bottom. Some force might be needed. Set panel aside.
  2. Bravilor Bonamat THa Err 11, Locate the thermo fuse: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bravilor Bonamat THa Err 11, Locate the thermo fuse: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Did you remember to pull out the power lead ?
    • Locate the metal cylinder inside. This is the heating core. The thermo fuse and reset button is located on top behind the power leades. Did you really disconnect power ?
    • Reach in from the left side behind the power leads and push lightly on the little button marked with red in picture 2. You will feel a little snap and a little movement if it resets.
    • If nothing happens, then your problem lies elsewhere. I am really sorry.
Kjetil Jensen
crwdns2935283:009/14/24crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 169
crwdns2942667:0crwdne2942667:0 1,063
