Braven BRV-X Button Module(s) Replacement
  1. Braven BRV-X Button Module(s) Replacement, Front Speaker Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Button Module(s) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Button Module(s) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the outer shell.
  4. Braven BRV-X Button Module(s) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Button Module(s) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Button Module(s) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Button Module(s) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Button Module(s) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Button Module(s) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Button Module(s) Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Button Module(s) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Button Module(s) Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Braven BRV-X Button Module(s) Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
  13. Braven BRV-X Button Module(s) Replacement, Button Module(s): crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-X Button Module(s) Replacement, Button Module(s): crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ribbon cable attached to the main board.
    • Pull from the clip and not from the cable.
  14. Braven BRV-X Button Module(s) Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 0.7 cm screws from the button module(s) using the Phillips #00 screwdriver.
  15. Braven BRV-X Button Module(s) Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the button module from the enclosure.
Trey Peterson
crwdns2935283:004/01/19crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G5, Harley Spring 2019 crwdns2935289:0IUPUI, Team S1-G5, Harley Spring 2019crwdne2935289:0
IUPUI-HARLEY-S19S1G5
crwdns2942667:0crwdne2942667:0 500
