The following step-by-step guide will show how the power button can be located and replaced. The Braven BRV-HD Battery Replacement is a prerequisite for this guide.
Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
Lift the front panel off of the speaker using a plastic opening tool.
Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
Lift the back panel off of the device with a plastic opening tool.
Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
Remove the outer rubber flap and the plastic side port panel.
Place the device on its front.
Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
Pull off the rubber sleeve surrounding the speaker using your hands.
Lift the black covering off of the speaker using both hands.
Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
Remove the two brackets that hold down the battery using your hands.
Use the plastic opening tool to lift up the battery.
Remove the battery using your hands.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the wire attaching the battery to the motherboard.
Place the device so the blue button panel is facing up, and use a J00 Phillips J1 head screw driver to remove the two 7mm Phillips head screws on either side of the button panel.
Unplug the wire on the inside of the device that connect to the button panel.
Pry the button panel off of the speaker using a nylon spudger.
