Braven BRV-1s Auxiliary Ports Replacement
  1. Braven BRV-1s Auxiliary Ports Replacement, Auxiliary Ports: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-1s Auxiliary Ports Replacement, Auxiliary Ports: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Please be aware that dismantling your Braven BRV-1s will make it cease to be waterproof.
    • Using a 0mm Philips Head screwdriver, unscrew the four 0.9mm screws located on the bottom of your device.
  2. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Opening the Braven BRV-1s is very difficult as the case is glued shut. If need be, use a heat pad or other device to heat up and melt the glue.
    • Take a metal spudger and insert it into the bottom seam.
    • Work the spudger around the bottom seam making sure that bottom of the speaker is no longer glued onto the rest of the speaker.
  3. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry upward on the spudger until the bottom of the speaker is removed.
    • This is very difficult. Be sure to pry with care and avoid prying towards yourself. You will want to pry away from yourself in case the metal spudger suddenly becomes loose.
  4. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Underneath the bottom of the case you will find a passive radiator.
    • Using a 0mm Philips Head screwdriver, unscrew the 10 0.6mm screws located around the outside of the woofer.
  5. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This area is glued down as well. Use a heat pad or other heating device if needed.
    • Insert the metal spudger between the seam of the woofer.
    • Glide the spudger around the seam to loosen the woofer and get rid of excess glue.
  6. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull upward on the woofer until it is removed.
  7. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam padding located in the Braven BRV-1s.
  8. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a 0mm Philips Head screwdriver unscrew the three 0.6mm screws on the auxiliary circuit board.
  9. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the circuit board via the outer auxiliary ports out of the speaker.
    • You may wish to use a tool to push the circuit board out via one of the auxiliary ports.
  10. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soldering irons get extremely hot. Be sure to wear proper protective wear and keep it away from exposed skin while it is turned on.
    • Turn your soldering iron on to high.
  11. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You may wish to use a heat gun to melt excess glue around the wires.
    • Using the soldering iron, desolder the wires from the circuit board.
  12. Braven BRV-1s Auxiliary Ports Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have soldered the glue off, remove the wires by pulling upwards.
Jai Blair
crwdns2935283:009/28/15crwdne2935283:0
233 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Matresse Fall 2015 crwdns2935289:0Eastern Washington University, Team 1-2, Matresse Fall 2015crwdne2935289:0
EWU-MATRESSE-F15S1G2
crwdns2942667:0crwdne2942667:0 1,375
