Learn how to properly open the Braven BRV-1s case and remove the circuit board to replace your auxiliary ports.
Using a 0mm Philips Head screwdriver, unscrew the four 0.9mm screws located on the bottom of your device.
Take a metal spudger and insert it into the bottom seam.
Work the spudger around the bottom seam making sure that bottom of the speaker is no longer glued onto the rest of the speaker.
Pry upward on the spudger until the bottom of the speaker is removed.
Using a 0mm Philips Head screwdriver, unscrew the 10 0.6mm screws located around the outside of the woofer.
Insert the metal spudger between the seam of the woofer.
Glide the spudger around the seam to loosen the woofer and get rid of excess glue.
Pull upward on the woofer until it is removed.
Remove the foam padding located in the Braven BRV-1s.
Using a 0mm Philips Head screwdriver unscrew the three 0.6mm screws on the auxiliary circuit board.
Push the circuit board via the outer auxiliary ports out of the speaker.
Turn your soldering iron on to high.
Using the soldering iron, desolder the wires from the circuit board.
Once you have soldered the glue off, remove the wires by pulling upwards.
