Braven BRV-1M Outer Casing Replacement
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
    And where do I purchase a new outer case? My on off button rubber perished.
    Louise Maree - crwdns2934203:0crwdne2934203:0
Erik Oliva
crwdns2935283:002/14/18crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G1, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G1
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 713
