Braven BRV-1M Motherboard Replacement
  1. Braven BRV-1M Motherboard Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once disconnected, carefully remove the motherboard by pulling upwards.
Erik Oliva
crwdns2935283:002/14/18crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Eyestone Spring 2018 crwdns2935289:0USF Tampa, Team S2-G1, Eyestone Spring 2018crwdne2935289:0
USFT-EYESTONE-S18S2G1
crwdns2942667:0crwdne2942667:0 312
