Braun Shaver Model 7680 Battery Replacement
  1. Braun Shaver Model 7680 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soldering is required to install this battery one or two batteries may be required verify how many you need before you order
    Anleitung passt auch für Syncro Typ 5492, Modell 7540
    Garofalo - crwdns2934203:0crwdne2934203:0
  2. Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braun Shaver Model 7680 Battery Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First pry the left side of the cover off, then pry the right side of the cover off before removing. Trying to pry the cover off from only one side will result in breaking the plastic tabs.
    First you must remove the very bottom cover. Where the electrical plug goes in. Then the covers practically fall into your hand(s).
    Raoul F Lange - crwdns2934203:0crwdne2934203:0
  3. Braun Shaver Model 7680 Battery Replacement, Remove side covers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the side covers off from the bottom, they hinge from the top and will come off freely once you rotate them up and away from the body starting at the bottom.
    Must remove the very bottom cover first, where the electrical plug goes in.
    Das Aufhebeln der kleinen Abdeckplatte am Steckkontakt ist der Clou. Ohne diese Anleitung hätte ich den Rasierer nich öffnen können. Vielen Dank für den Tip.
    Robert Reiner - crwdns2934203:0crwdne2934203:0
  4. Braun Shaver Model 7680 Battery Replacement, Remove screws on back: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Braun Shaver Model 7680 Battery Replacement, Remove screws on back: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will need a T9 hex screw driver.
    die freigelegte Schalterschale “6” keinesfalls betätigen - federn fliegen ! - den schräg liegenden Hebel mit dem linken Daumen halten, mit schmalem Pinsel entstauben. Zum Lösen von Stoppelresten / staub Scherkopfreiniger aufsprühen , ich benutze “Multistar”, den sanftesten Schmutzlöser ( im Internet suchen, )
    Garafalo’s invaluable comment, translated from German: “Never operate the exposed switch shell “6” - feathers fly! - Hold the inclined lever with your left thumb, remove dust with a narrow brush. To loosen stubble residues / dust, spray on the shaving head cleaner, I use “Multistar”, the gentlest dirt remover (search on the Internet)“
    Also, on the 7680 the screws will accept a flat-bladed screwdriver with a 1/8” (4.2mm) tip.
    Stephen Spratley - crwdns2934203:0crwdne2934203:0
    • R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm
    Vor Auslöten der Akkus ( beim 7540) Pluspole markieren, auch auf der Platine, sind dort nicht angezeichnet.
    Garofalo provided a valuable comment which I’ve translated here from German: “Before unsoldering the batteries (on the 7540) mark the positive poles, also on the circuit board, they are not shown there.”
    This was also applicable to my 7680.
    • Replacing the batteries will not always repair the shaver, the circuit board may be bad, if the indicator lights on the circuit board do not light up when plugged in the circuit board is most likely bad, you should replace the entire circuit board and battery assembly.
    Dank an Stephen Bratley für den Versuch, meinen Hinweis zu den “fliegenden Federn”
    ins Englische zu übertragen, hier sind jedoch keine Hühnerfedern ( feathers) gemeint,
    möchte eher so übertragen: “ … springs might jump away …..”
crwdns2935229:019crwdne2935229:0
mayer
crwdns2935283:001/04/10crwdne2935283:0
688.084 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
MacHale Enterprises crwdns2935289:0MacHale Enterprisescrwdne2935289:0
Business
crwdns2935297:019crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Great tutorial. It was all I needed, since I wasn't sure how to get the case open. Thanks!
mikebailey - crwdns2934203:0crwdne2934203:0
Thanks for the tutorial! Mine had intermittent problem with the on/off switch and I was googling how to open the case. Easy and simple, bets razor I’ve had and not willing to change :D
Tero Kortetmäki - crwdns2934203:0crwdne2934203:0
Thanks for the tutorial… but it is a T8 Torx at least in the Model 7570. I just had to take out the recharchable batteries to get mine working properly again.
A Krueger - crwdns2934203:0crwdne2934203:0
Danke für die übersichtliche Anleitung, hat mir gut geholfen. Die wichtige Frage ist immer:
Wie geht ‘s Gehäuse auf. ?
Thanks for the guide! Without knowing how to open the case, replacing the battery would have been a lost cause. In my case the batteries were tired. After replacing and recharging them the razor sounds young again and full of pep.
There is a spring and a black component that sits in the top cover. Does anyone have an exploded view that shows how these are installed?
Edward h - crwdns2934203:0crwdne2934203:0
I think i found it on this youtube
Edward h -
Leider keine gute Montage-Anleitung, da ein entscheidender Hinweis fehlt.
WICHTIG - BITTE BEACHTEN:
Die Akkus MÜSSEN vor der Montage und Verlötung vollständig entladen sein. Sonst erkennt die Ladesoftware die vollen Akkus als leer und startet den Ladevorgang nie mehr!
Hans Meier - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 22,936
