Broken bra underwire can be a painful problem. Not only can it pierce skin, but it can ruin the support of the bra. Luckily, there’s a quick fix for replacing the broken wire with a new one. This manual will cover each step from removing the broken wire to using basic sewing skills to close up the hole.
Choose a thread that is a similar color to the bra.
Insert the thread into the eye of the needle.
Tie a double-knot.
Poke the needle through the bottom of the hole in the fabric.
Loop the needle through the top of the hole.
Guide the needle back through the bottom of the hole.
Repeat steps until the hole is closed.
Slide the needle under your last stitch.
Pull it through the stitch.
Tie a double-knot.
Cut the excess thread off.
Protect the stitches by placing a few drops of fabric glue onto the casing.
