Bowers and Wilkins T7 Speaker Driver Replacement
  1. Bowers and Wilkins T7 Speaker Driver Replacement, Access Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
    My model does not have screws in the front as indicates here. Not sure what to do now
    thebolts - crwdns2934203:0crwdne2934203:0
  2. Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
    FYI: I bought the Ifixit toolkit and sadly the screw driver isn’t long enough to remove the 4 middle screws.
    Jonathan Keay - crwdns2934203:0crwdne2934203:0
    What sizes are the screws exactly? I took mine apart and someone threw out the screws so now I need replacements.
    Pablo Escobar - crwdns2934203:0crwdne2934203:0
  3. Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
    I tried this with the ifixit tool, but I could not remove the cover
    m6rtg - crwdns2934203:0crwdne2934203:0
    I used a sharp knife. Note carefully where the seam is in the above diagram: on the back about 7 mm from the edge.
    al.germain - crwdns2934203:0crwdne2934203:0
    Remove the outer rubber completely. Then you need to peel back (or peel off) the black sticky tape from the sides nearest the front to reveal the seam. When all peeled back, the two halves come apart easily with no tools
    Matt - crwdns2934203:0crwdne2934203:0
  5. Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
    You don't need to do this step for either speaker to replace the battery, the cables are long enough. The other end is easier to unplug anyway (red and white clips in the bottom left of the body, see picture from step 6)
  6. Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
    • There are 4 screws in total around each speaker.
  7. Bowers and Wilkins T7 Speaker Driver Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that all the screws are removed, pull straight up on the speaker drive to remove the speaker drive component.
Oluwagbemisola Aderibigbe
crwdns2935283:002/27/17crwdne2935283:0
257 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S7-G1, Cagle Spring 2017 crwdns2935289:0USF Tampa, Team S7-G1, Cagle Spring 2017crwdne2935289:0
USFT-CAGLE-S17S7G1
Where do you buy the replacement driver?
nigellittledesignandmedia - crwdns2934203:0crwdne2934203:0
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
Phương Trần - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,337
