Bowers and Wilkins T7 Battery Replacement
  1. Bowers and Wilkins T7 Battery Replacement, Access Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
    • Be careful not to damage the battery while cutting the cable tie surrounding the battery.
  7. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the ifixit Opening Tool, pry out the battery power supply connector.
    • Pull and remove the battery power supply connector.
  8. Bowers and Wilkins T7 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bowers and Wilkins T7 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After disconnecting the power supply connector, pull the battery out of its case.
crwdns2935229:012crwdne2935229:0
Bertrand Plummer
crwdns2935283:002/28/17crwdne2935283:0
323 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S7-G1, Cagle Spring 2017 crwdns2935289:0USF Tampa, Team S7-G1, Cagle Spring 2017crwdne2935289:0
USFT-CAGLE-S17S7G1
Bravo ! Le choix de cet appareil symbolique !
Pierre Vanhoorenbeeck - crwdns2934203:0crwdne2934203:0
Seriously
Couldn't the lady get her
'nails did’
Lux Valet - crwdns2934203:0crwdne2934203:0
Brilliant instructions , thank you so much. Just dont worry about trying to remove the connectors for the speakers its too difficult ! and you risk damaging the wires - Just hope my new battery works when it comes from Amazon ! Greta speaker but had it replaced already under warranty due to the battery issue ! now same fault - hope it doesnt happen again but at least I know I can replace it myself now - thanks again
Jacqueline Banks - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 11,888
