Use this guide to learn how to take off or replace your access panel for the Bowers and Wilkins T7 speaker, enabling you to replace every other part.
Gently lift up the access panel; it should easily "pop" open.
Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
There are 8 screws in total.
Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
As the cover starts to come off, you can lift up using your hand.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
I found that removing the speakers terminals was very difficult and could only get 1 to come off - I still was able to easily remove the battery and so dont think its necessary to remove the speaker connectors as long as you are careful not to damage them !
