Close the display and lay it on a flat surface, top-side down.
Unlock the battery by sliding the battery lock to the unlock part.
Slide the middle lock to the right and the battery will pop up.
Once the battery hatch is unlocked you can now safely remove the battery.
Remove all of the 8 screws and the bottom panel should pop off.
After that you are in and now can change most of the components, which we also have tutorials for.
