flip speaker over onto its back
using a heat gun, soften the adhesive holding the ring in place.
peel off the ring that covers the screws
using your screwdriver, undo the 4 screws that hold the base onto the body of the speaker.
using your heat gun, apply a slight amount of heat to soften the adhesive.
using your screwdriver, undo the 4 screws holding the speaker assembly in place.
carefully pry in the edge of the speaker assembly.
using a spludger, carefully disconnect the speaker cables from the motherboard.
using your spludger, carefully pry up the battery.
using 2 fingers, pinch the connector connecting the battery and pull it straight out.
