Bose Soundlink Revolve Speaker Replacement
  1. Bose Soundlink Revolve Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool or metal spudger to remove the rubber mount from the bottom of the speaker.
  2. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 screwdriver to remove the three 10 mm screws from the bottom of the speaker.
    This is not a T10 screwdriver at all... T10 have 6 branch star...bose screw have only 5...
    Martin - crwdns2934203:0crwdne2934203:0
    Es scheint hier unterschiedliche Versionen zu geben.
    Diese Schrauben sind bei meinem Gerät noch T10, die 5-Stern Torx-Sicherheitsschrauben mit Mitteldorn kommen erst nach dem abnehmen des Bodens als nächstes, dieser wichtige Schritt, ohne den Schritt 5 und 6 nicht möglich sind, fehlt aber leider in dieser Anleitung hier!
    mich.kurz - crwdns2934203:0crwdne2934203:0
  3. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the ribbon conector that connects the bottom cover to the body, then remove the bottom part of the speaker.
  4. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a TR9 screwdriver to remove the screws from the top of the speaker, and then remove the top part of the speaker along with the motherboard.
    What screw are we removing here?
    andrewpalozzo - crwdns2934203:0crwdne2934203:0
  5. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the body of the speaker from the metal cover.
  6. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 screwdriver to remove the four 6 mm screws around the 2 speakers, and remove the speaker units from the body.
  7. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the metal case from the speaker body.
    Zwischen Schritt 7 und 8 fehlt der Wichtigste: Um an die T10 Schrauben in Schritt 8 heranzukommen muss vorher noch der Teller mit der weißen Silikondichtung in Bild 7 demontiert werden. Hier steckt der Teufel im Detail:
    Hierfür benötigt man ein 5-Stern(!) Torx Bit mit Bohrung in der Mitte, und sowas gibts auch im IFIXIT-Shop (noch) nicht. Das "Pentalobe" -Profil aus dem Set passt hier nicht (zu spitz und zu klein), selbst wenn man den Mittelzapfen der sog. IPR-Sicherheitsschrauben herausbricht, es passt tatsächlich KEIN missbräuchlich verwendetes anderes Profil, auch mit einem Schlitzschraubendreher (ersatzweise möglich bei Torx mit 6 Zacken) funktioniert bei 5 Zacken nicht.
    In diesem Fall liegen die Schraubenköpfe zum Glück nicht versenkt und ich habe einfach mit der Mini-Bohrmaschine einen Schlitz reingeflext und so die Schrauben entfernt. NUR dann kommt man zu Schritt 8 :-)
  8. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 25.3mm screws from the bottom part of the speaker body with a T10 Torx screwdriver.
  9. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry apart the glued section between the speaker panel and the device.
  10. Bose Soundlink Revolve Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the speaker panel, then unwind the three wires from the speaker.
    From where I can get mother board and fct cable
    Ghanshayam verma - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Ruoyu Han
crwdns2935283:001/14/19crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G1, Wilson Spring 2019 crwdns2935289:0IUPUI, Team S1-G1, Wilson Spring 2019crwdne2935289:0
IUPUI-WILSON-S19S1G1
crwdns2947412:08crwdne2947412:0
Is it possible to buy a replacement subwoofer? Mine has been dropped and it's only the bass elements that sound distorted, thank you
weedon2759 - crwdns2934203:0crwdne2934203:0
Subwoofer with sound distorted at my revolver speaker
david garcia Lopez - crwdns2934203:0crwdne2934203:0
I also cannot find a subwoofer replacement on the web. Do you know where I can buy one?
davlopest - crwdns2934203:0crwdne2934203:0
BOSE has a $75 option to refurbish the speaker, they do not sell the parts…..
chip - crwdns2934203:0crwdne2934203:0
Im glad to hear . I live in Puerto Rico and the authorized store wants to charge me $169.00 for a replacement. How do i go about this service . Thanks Bert
Humberto nieves -
Where's the best place to hide an airtag in this Bose speaker? In your opinion that is. (Airtag is modified to not have a working beeper)?
Victor - crwdns2934203:0crwdne2934203:0
I am working in repair cafés and had one yesterday. I was disappointed about these screws, which I could not open with my iFixit screw set (Pro Tech). It was not Torx. Maybe Bose changed it for some models. I am missing a pentalobe screwdriver with a hole in the middle. The P6 (should be named PL6 by the way) from the Pro Tech Toolkit is too small and has no hole.
Since the battery started charging with another power supply, we did at least not have to open it.
I am very interested in a tool opening those screws and how they are named. Maybe I could abuse a kind of spanner driver or create one myself.
RJ Lutz Bonn - crwdns2934203:0crwdne2934203:0
I did some research and these screws are called Torx star 5 point (translated from German), which is in my opinion not an official designation. According to Wiki, these should be Torx Plus Security. Torx Plus was patented by the company Acument.
Just funny, that I already HAD these in my car for coffee machine repairs... But I didn't know, that 'Torx' could have been 6 and 5 star. Since the designation seems not to make a clear diefference.
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 128
crwdns2936753:030crwdne2936753:0 464
crwdns2942667:0crwdne2942667:0 23,058
