Use this guide to replace the bottom motherboard of your device.
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the screwdriver, unscrew three screws.
Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
These are not the screws I have in my bose speaker. These are standard TORX screws ( with 6 sides) bose uses a special 5 sided secure torx screw(with a dot in the middle of the hole). A screwdriver or a screw-bit for these screws is very hard to find. I am still searching for one
The 5 pointed Torx is also known as Torx Plus or an "IPR" bit, and you will have to get the security version with the hole. You are correct that they are hard to find. I searched several places locally but online was the only only way to go for me. ProTorq has an appropriate set available.
Remove the screw that is above the charging port.
Remove the two screws connecting the motherboard to the bottom cover of the speaker.
Remove the bottom cover.
Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
Remove the AUX/USB port from the device.
Where do you buy the usb/ aux port .
I have a charging cradle and it still flashes red light not charging
Where do I find this part?
Bohdan Tomanek (emerysteele) - crwdns2934203:0crwdne2934203:0
So maybe you have to work at Bose to get the part?
Hi! Where do I find this part?
Where can I find this part
I just wanted to find out if any android port can be connected and work or they are specific. Also when hot wiring the cables, is there a particular pattern or anything goes?
How does one reattach the latch here exactly?
Bonjour, ces explications sont très claires mais il reste beaucoup à démonter et surtout on ne sait pas trouver la pièce défectueuse, sans parler d'en trouver une de rechange... Merci quand même mais le chemin est encore long pour réparer cet appareil...
I suppose if you could open that thing, which might be hard (every smartphone today :D) to impossible without destructing the whole thing (eg Apple usb 3.0 camera adapter) - I haven’t tried it yet -, it’s an easy thing to desolder the ports and replace them with some from eBay or any other platform to buy stuff.
Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
Remove the motherboard from the device.
crwdns2947412:043crwdne2947412:0
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: gonzser@gmail.com
Thank you
Gonzalo
Hey Brian I also need the circuit board for the nose revolve and the battery. If you can help me. Thanks my email is lambertjsmith@gmail.com
Hello Brain. I cannot find were to buy bottom circuit board for bose revolve. Could you sell it for me. mail: Rick bull566@aol.com
Thank you
Hi. your guide is great and just what i needed. can you tell me where to purchase a usb port and lower circuit board? thx.
heres my email: andrew.demchuk@yahoo.com
Hi Brain, I also need to replace bottom circuit board for Bose revolve. Can you tell me where to buy it? My mail: bjspeek@live.nl
Just broke the ribbon connector when taking this thing apart. Do you know where I am able to get a replacement bottom circuit board Brian?
hamishwoyka@gmail.com
Where can I find the bottom circuit board ? Jlorusso24@gmail.com. Thank you!
Hello, I too need to buy a new bottom circuit board for the Bose SoundLink Revolve. jaburge1@gmail.com. Thank you!
Hi I require the bottom circuit board are you able to provide this item for sale. david_lee24@hotmail.co.uk
Need to buy board and cable, please. reimao@gmail.com
Hello Brain.
Could you sell it for me?
mail: fabforrun@gmail.com
Thank you
Fabien
Hey thank you for the help but where can i buy the bottom circuit board. pls?
My contact slwebuse@gmail.com
regards,
scott
Hello, do you sell the bottom circuit board for bose? , could you sale it for me: mail: sa_alexandre@hotmail.com, delivery to Brazil. Best regards
Hello i need the bottom circuit board for the revolve Bose
do you sell it ? Or can you tell me where can I get it ? guillermo_alc@hotmail.com
Hello, I would also need the circuit replacement board. My email is Jolilum1@gmail.com
Thanks a lot,
Juan.
bottom circuit board link ? I need one as well
Alan.cyr(AT)gmail(dot)com
Hello, I am also looking for the bottom circuit board for Bose Revolve. Thanks, regards, efreibox@hotmail.com
Hello, as anyone know where we can find the bottom circuit board. Thank you, efreibox@hotmail.com
kkc6143@gmail.com
I am also looking for the bottom circuit board for Bose Revolve. michael@parsche.net
Anyone found where to buy this circuit board?
hello, I’m also looking for the sparepart.Did you get any news regarding where to buy it?
Thanks in advance
hello i have broken the tablecloth on the board where to find it ???
Hello, nice tutorial, how to get the item? Can you send one to France? Veens876@gmail.com
Need the bottom circuit board where can i buy it .
Hello, I’d also would like to buy a bottom circuit for bose revolve. Do you know where I could find it ?
Thank you for helping and for your site.
Romain
cornazro@gmail.com
Hi Friends,
I got a supplier for original power circuit board but price is not cheap. Is there any that we can direct purchase from Bose?
Hi thanks for this tutorial, i need the circuit board for this bose revolve. Do you sell it ?
my mail : gregory@adelios.fr
Thx
G.C
Hello, where you able to purchase this from a website? regards Gareth
is there a website where i can buy the circuit?
Hello do you sale replace my parts?
Where can one purchase this circuit board? Haven't been able to locate one anywhere.
wo und wie kann ich den ganzen Platine kaufen
i need the bottom board, can i know the cost
Hey there, I also require the bottom circuit board for my Bose Revolve at India, lakshmanan1413@gmail.com
Looking for a usb charging port for a bose revolve bluetooth speaker.
Is it possible to add a high resolution closeup of both sides of the PCB please? I have one for repair, and it is missing components, but I am unable to find out the ratings of the missing components.
Hi, i'll try my luck but is the ribbon mentionned in step 6 available somewhere ?
gainon.cyril@hotmail.fr in austria
