Bose Soundlink Mini II charging port Replacement
    • flip the speaker over onto its back, then open the rubber covering the battery.
    • unscrew the battery using your screwdriver. carefully disconnect the battery from the motherboard.
    • be very careful not to damage the connector.
    • when replacing the battery, re apply the adhesive strip.
    • leave the battery aside.
    • carefully using a spludger, pry up the rubber holding the grills in place. then pry off the grill.
    • Be very careful with the grill as they bend easily.
    • using your spludger, carefully disconnect the ribbon cable connecting to the motherboard.
    • carefully remove the charging port assembly.
    • be VERY careful not to damage disconnecting the ribbon cable from the connector.
    • carefully pull out the charging port assembly.
    • be Extremely careful when attaching the new port to the assembly.
    • when replacing the port assembly, add the adhesive under the port.
776831
crwdns2935283:006/10/21crwdne2935283:0
1 025 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 2,195
