Bose Soundlink Flex Driver Replacement
  1. Bose Soundlink Flex Driver Replacement, Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Driver Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Driver Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink Flex Driver Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Driver Replacement, Driver: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose Soundlink Flex Driver Replacement, Driver: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose Soundlink Flex Driver Replacement, Driver: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Driver Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose Soundlink Flex Driver Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose Soundlink Flex Driver Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
  6. Bose Soundlink Flex Driver Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Soundlink Flex Driver Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the joints that are connecting the speaker to the motherboard.
    • Solder the new speaker with the wire color in the same order.
    • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
Kalvin Lee
crwdns2935283:003/19/24crwdne2935283:0
501 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 crwdns2935289:0UMass Dartmouth, Team 4-1, Shaddix Spring 2024crwdne2935289:0
UMASSD-SHADDIX-S24S4G1
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 624
