Remove the two T-10 machine screws at the bottom of the device.
Turn the device around.
From the top, lightly push down the back cover to release it.
Lift the bottom of the cover and pull it up.
Remove the two T-10 machine screws, then pull the battery straight out.
Remove the two screws using a torx screwdriver.
With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
Remove the two T-10 Torx screws
Remove the black casing
Pry off flat connector
