Bose SoundTouch Portable Subwoofer Replacement
  1. Bose SoundTouch Portable Subwoofer Replacement, Speaker Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Subwoofer Replacement, Grille: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Subwoofer Replacement, Metal Trim: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws using a torx screwdriver.
  8. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  9. Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the case that holds the subwoofer in place.
    • Be careful when doing this step because there are several connectors inside.
  10. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
  11. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws from the subwoofer and lift it out of the casing.
Chelsea Martin
crwdns2935283:002/20/17crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G3, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G3
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
Outdoor Sumo - crwdns2934203:0crwdne2934203:0
About more: ++https://compactcarsubwoofer.blogspot.com...
crwdns2942667:0crwdne2942667:0 1,558
