Bose SoundTouch Portable Subwoofer Replacement
  1. Bose SoundTouch Portable Subwoofer Replacement, Speaker Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two T-10 machine screws, then pull the battery straight out.
    Eine Bezugsquelle für den Akku wäre interessant. Ich habe drei Akkus ausprobiert, keiner konnte geladen werden. Über die Service Buchse wäre ggf. etwas mit entsprechender Software möglich gewesen, war mir zu kompliziert.
    Alexander - crwdns2934203:0crwdne2934203:0
  4. Bose SoundTouch Portable Subwoofer Replacement, Grille: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Subwoofer Replacement, Metal Trim: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws using a torx screwdriver.
  8. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  9. Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the case that holds the subwoofer in place.
    • Be careful when doing this step because there are several connectors inside.
  10. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
    Nice sharing for how to install a subwoofer, amplifier and enclosure on the car or vehicle right location to perfect setting. It is a very helpful post for those who want to fix a subwoofer on their rider location.
    ++About more: https://compactcarsubwoofer.blogspot.com...
    Outdoor Sumo - crwdns2934203:0crwdne2934203:0
  11. Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose SoundTouch Portable Subwoofer Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws from the subwoofer and lift it out of the casing.
Chelsea Martin
crwdns2935283:002/20/17crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G3, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G3
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
About more: ++https://compactcarsubwoofer.blogspot.com...
crwdns2942667:0crwdne2942667:0 1,558
