Remove the two T-10 machine screws at the bottom of the device.
Turn the device around.
From the top, lightly push down the back cover to release it.
Lift the bottom of the cover and pull it up.
Remove the two T-10 machine screws, then pull the battery straight out.
Remove the two screws using a torx screwdriver.
With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
Remove four T-10 Torx screws; there are two on the front and two on the back.
Pinch and remove the connectors.
Use a flat tool to pry off the top piece.
Remove the four T-10 Torx screws holding the plastic cover in place.
Remove the one T-10 Torx screw that is holding the motherboard in place.
Pry off the motherboard.
