This guide will show you how to remove the cover and the motherboard for the Bose SoundTouch 20.
Remove the (6) six 1.5mm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
Lift the cover straight up and set the cover aside.
Gently pull the white ribbon from the connector on the top side of the power board.
Remove the (4) four 1.5 cm screws connecting the power board to the speaker.
Remove the (2) two 1 cm screws connecting the power board to the speaker.
Gently lift the board up.
Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
Gently pull the thinner white ribbon towards the center of the board.
Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
Remove the motherboard.
crwdns2935229:05crwdne2935229:0
crwdns2947412:07crwdne2947412:0
But how do I purchase a new motherboard?
Thank you for excellent information and instruction. Can you please send some link to order a new motherboard?
Thank you for the tutorial. How do I purchase a new motherboard ?
Any known place to purchase a replacement board?
Any luck with a place to purchase a replcement board ?
Aber wo bekomme ich das neue Motherboard?
i want the motherboard
Saleem Al shukairi - crwdns2934203:0crwdne2934203:0
from where i can get the motherboard?
I need this mainboard
yosoymichael - crwdns2934203:0crwdne2934203:0
