If the audio from your SoundTouch 10 is muffled, distorted, or completely silent, you may need to replace the speaker entirely. Be careful when handling the motherboard as it contains capacitors which may hold a charge even while the speaker is unplugged.
Turn the speaker over so that the rubber strips along the bottom are facing you.
Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
Lift the panel away to reveal the speaker head.
Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
Flip the speaker onto its back.
Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
What is the serial number or spare part number of that ribbon.
Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
Only the upper part takes off (the one that is whiter). The other part coresponds to the base, and it is unremovable
To remove the plug, squeeze the very top of the plug to unlatch the plug, then pull on the plug to remove it.
Where can I buy parts at?
Use a #2 Phillips screwdriver to remove each of the four 15mm screws holding the speaker in place.
You can now lift speaker/driver completely away from it's housing.
Hi I need to get a replacement for the driver. Would you know the specs or where to get them from? Bose support has not been very helpful with this , since I live outside of the US and repair would be expensive, I need to purchase the driver only to fix it myself. Any advise would be appreciated.
My wife recently dropped the Soundtouch 10 on a tile floor. Upon impact, we have no lights- no sound- nothing. Please advise? I have no idea what could be damaged. Thank you!
Hello I needed to reconnect my capacitor on my Bose Soundtouch 10 after dropping speaker. The IFixit steps to open the speaker were perfect! After reconnecting capacitor, shaking the speaker was no longer required.
BillJ - 06/30/20
Mi bocina aparece que se conecta blue toot en teléfono u otro pero no se escucha nada de echo en mi telefono aparece que esta funciinando pero no suena. Ni da el sonido bip cuando se conecta. Como o que ocupo revisar?
