Bose SoundLink Mini Front/Back Protective Grille Replacement
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    Woher bekomme ich nun rin solches Vorder- und Rückgitter?
    [COBS]CR4ZY BLITZ - crwdns2934203:0crwdne2934203:0
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Mini Front/Back Protective Grille Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat steps to remove the back grille.
    Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
    Pierre Payette - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Jordan Smith
crwdns2935283:010/01/15crwdne2935283:0
923 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-23, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 1-23, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S1G23
crwdns2935297:021crwdne2935297:0
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - crwdns2934203:0crwdne2934203:0
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - crwdns2934203:0crwdne2934203:0
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - crwdns2934203:0crwdne2934203:0
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - crwdns2934203:0crwdne2934203:0
Steps are wrong and difficult. Try taking out from somewhere between the center, it will automatically pull the locks out which are located on the sides.
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 13,862
