Bose SoundLink Mini Battery Cover Replacement
crwdns2942287:0crwdne2942287:0The battery cover is the rubber flap on the bottom of the speaker that covers the battery. It cannot be pulled off without first going through several prerequisite steps. This guide will provide you with easy to follow steps to remove the battery cover on the Bose SoundLink Mini speaker.
crwdns2944105:0crwdne2944105:0
            Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
            While holding the cover back, pull straight up on the battery to remove it.
 Where can I buy this battery Well that part was simple. What I need is how to disconnect the ribbon cable which is soldered in on both ends. No help here. soweit sogut..aber die Kabel sind verlötet ? das ist ja das problem also sehr schlechte Anleitung da ja das wichtigste fehlt !! Bonjour pas aussi simple car les câbles de la batterie d origine sont soudés… On remark though: the original Bose battery has a thin foam gasket at the base. This foam gasket makes sure the room behind the speakers is airtight, which is essential for a clean sound. Most aftermarket batteries do not have this gasket, leading to a thumping noise when you turn up the music. This is easy to fix: with a sharp cutter, gently peel the gasket from the original battery and reinstall is on the new battery. That solved the problem for me. Alternatively, you can cut a think sheet of PE foam to fit the base of battery. Cable is not soldered on BOSE SoundLink Mini! The situation is different on BOSE SoundLink Mini II. The procedure to replace battery is more demanding as the cable is soldered. iFixit日本語版からこのバッテリーパーツの購入ボタンを押すと、米国サイトにリンクされていて、当然ながらバッテリーは米国内以外では買えません!となります。何のための購入ボタンなんでしょうかね。時間の無駄でした。
            Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
 Woher bekomme ich nun rin solches Vorder- und Rückgitter?
            Slowly pry up the grille until the two tabs shown pop out.
            The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
            Repeat steps to remove the back grille.
 Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
            Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
 le circuit de gauche ci-contre a les 4 vis de 15 mm prenez-en note.
            Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
            Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
 I just want to emphasize that the rubber tab (that is part of the cover) is supposed to sit ON TOP of the circuit board. In my case, my son managed to pull of the battery cover off completely, so as I was taking it apart I didn’t see how the rubber tab was actually supposed to sit inside the box. Because these instructions have you unseat the circuit board, I thought it was implying the tab was supposed to sit under the circuit board. But that is NOT the case! If I had looked at the pictures 7 and 9 more carefully, I would have seen how things were supposed to sit. Instead I first jammed things back together with the rubber underneath the board (really hard to do), only to find that the slightly squeezed rubber tab pushed the cover out a millimeter so it wouldn’t sit right on the charger. On closer inspection, I figured things out.
crwdns2935229:08crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
can someone tell me how do i reattach the rubber battery cover if i have removed it completely
Cut the lip off. You will not be able to put it back. It’s Bose’s terrible design.
@rajpotus: I had the same problem. If the little rubber tab is not damaged (mine was fine), you should be able to follow these instructions to replace it. But I have these comments on the instructions:
1) You do NOT need to remove the front grill. I have no idea why they suggest you do that here.
2) I think the reason you remove the battery is to make sure the circuit board has zero power on it when you work on it — otherwise a touch of the screwdriver to an unlucky spot on the board might short/burn something out. But I don’t think there’s any mechanical reason to remove it.
3) Once you pop off the back grill cover, you should be able to slide the tab through the slot and coax it up (maybe with a tooth-pick and/or tweezers) on top of the circuit board, but it’s probably better to unscrew the circuit board (as directed here) which makes it easier to push the rubber tab through. Then slide the circuit board back under the tab and screw it back into place.
Help I removed the part which I'm not supposed to next to the battery charger how do I put it back?
Sooraj murali - crwdns2934203:0crwdne2934203:0
Where can I actually get a replacement battery????
appreciate any help bc I couldn’t find it anywhere.
Kamil M. - crwdns2934203:0crwdne2934203:0
Where can I get an actual replacement battery???
Hi Brent and thank you for this easy fix.
Still I have a problem I did not have while the original battery was in place: the sound is now buzzing even at a middle-of-the-range volume.
I used the original screws and everything seems in place and the screws are tightened “right” I would say. I am usually fine fixing things. And I do not see what I could have done wrong…
Any suggestion?
Thank you.
MBP - crwdns2934203:0crwdne2934203:0
Which battery is the correct one. Two model are shown to be purchase
Ruben Roman - crwdns2934203:0crwdne2934203:0
What is not discussed is the wires that connect the battery to the speaker. In mine, I think I destroyed the speaker, because I pulled out the battery and dislodged the wires from the electronic board. I think they must have been soldered on, and now am having trouble attaching the new wires to the board.
horseylawgal - crwdns2934203:0crwdne2934203:0
I have lost the 4 battery screws. What size are they? I think they are metric but what is the length? They were Philips head flat as I remember.
Wolfgang Mitchell - crwdns2934203:0crwdne2934203:0
