Bose SoundLink Color Speaker Replacement
  1. Bose SoundLink Color Speaker Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
    • Remove the inner assembly.
  5. Bose SoundLink Color Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The speakers are on the front of the inner assembly.
    • Using the Phillips head screwdriver, unscrew the four 1.3 cm screws holding the speaker that will be replaced.
  6. Bose SoundLink Color Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Three screws hold the printed circuit board.
    • Using the Phillips head screwdriver, unscrew the three 1.2 cm screws.
  7. Bose SoundLink Color Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose SoundLink Color Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder each the three pins connecting the speaker to the motherboard.
    • Carefully lift the motherboard with a spudger to ensure that each pin desolders.
    • Work carefully. Prying too hard may cause damage to the board.
  8. Bose SoundLink Color Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the speaker through the front of the inner assembly.
crwdns2935229:021crwdne2935229:0
Brett Horstketter
crwdns2935283:003/31/16crwdne2935283:0
2,870 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-4, Giguere Spring 2016 crwdns2935289:0Eastern Washington University, Team 1-4, Giguere Spring 2016crwdne2935289:0
EWU-GIGUERE-S16S1G4
crwdns2947412:013crwdne2947412:0
Thanks for this tear down. Never thought that it looks like this on the inside. My battery is kind off aging, bought the unit 7 months ago. Local Bose dealer said battery cost half of this speaker. I hope there is a cheaper alternative.
vintiglao22 - crwdns2934203:0crwdne2934203:0
You can unsolder the battery and replace with a standard unprotected 18650 cell it literally costs 7$ for a high quality sony or panasonic or samsung cell. The protection and charging circuit is included in the speaker motherboard just make sure you resolder with the proper polarity.
swiftink -
Speaker looks like a 18650 lithium ion- from the pictures here.
DR Paquette - crwdns2934203:0crwdne2934203:0
Does anybody know where one could order a spare speaker for this device?
sebastiansebisilva - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 381
crwdns2942667:0crwdne2942667:0 34,383
