This guide will show how to remove the 4 screws that are holding the two parts of the casing together and how to separate the casing for replacement.
Using a metal spudger, carefully pry up the plastic covers.
Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
crwdns2935229:013crwdne2935229:0
crwdns2947412:012crwdne2947412:0
When I search for a 1.8 cm Torx Plus TR drill bit, I see a whole set from Amazon. Is there a particular number or head size just so I can purchase one drill bit?
Hey, did you find out what size screwdriver you need?
yes its the number 5 torque
art -
dose anyone know where to buy the outer casing for these? i need a mint colored one.
I need more information on the Torx Plus bit can you provide the exact size as you used. The 1.8cm is not easy to search for. Brand and exact size number would help.
