Gently pry the front mesh cover off of the SoundDock using a metal spudger.
Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
Gently lift the speaker from the base.
You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
crwdns2947412:05crwdne2947412:0
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
How do you cut on without remote
