In this guide, you will learn how to replace the docking system on your Bose SoundDock Portable v2.
Lay the speaker flat on its back, balancing on the battery.
Remove the four rubber disks that cover the screws on the bottom of the speaker.
Follow the battery replacement guide to remove the battery
Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
Carefully remove the bottom panel of the speaker.
Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Once the pieces are separated, the dock connector can be lifted out of the slot.
Using tweezers or your fingers, unplug the two ribbon connectors from the board.
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I by this piece? I have to replace that piece.
PHelmut - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
