Bose Solo 5 Sound Bar Indicator Light Replacement
  1. Bose Solo 5 Sound Bar Indicator Light Replacement, Indicator Light: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
  2. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 18.25mm screws with a Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the gold plates and the snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, slightly lift the circuit board up and remove it from the housing.
  5. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the cords running to the white connector by pulling upon the tab until it is disconnected completely.
  6. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two clear LED receptors and note that one has two prongs and the other has three prongs.
  7. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate on the back of the control panel where it states LED 902, 903, 904, and 905.
  8. Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Solo 5 Sound Bar Indicator Light Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If there is any debris located in these locations, use the spudger tool to thoroughly clean the area.
To reassemble the sound bar, follow the steps listed above in reverse order.
Emma
crwdns2935283:010/05/18crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S15-G7, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S15-G7, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S15G7
crwdns2942667:0crwdne2942667:0 5,867
