Bose Series 1 or 2 Bluetooth Earpiece Battery Replacement
  1. Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a little hot air to soften the glue holding the two halves together. Then you can gently separate the halves.
    • Beware applying too much heat over the speaker grill as it will start to sag if it gets too hot.
  2. Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opposite end, do the same.
    • The crack was already there, thankfully I didn’t make it worse. A little super glue fixed it.
  3. Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the existing battery placement.
    • Note the old hot glue points.
  4. Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement, Carefully desolder the two battery terminals.: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement, Carefully desolder the two battery terminals.: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Note polarity of terminals.
    • Old battery size is 4.8 mm high, 12 mm wide, 21 mm long. .
  5. Bose Series 1 or 2 Bluetooth Earpiece  Battery  Replacement, Install new battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • New battery is 5 mm High, 12 mm wide and 20 mm long. It fit nicely.
    • Carefully solder new battery leads to correct polarity terminals on the circuit board.
    • Place a small dab of hot glue at each end of the case.
    • Gently snap the case back together .
Charge it up!
Mikee K
crwdns2935283:007/22/17crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 3,872
