Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement
  1. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement, Audio Jack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off ear cushion pad using the plastic opening tool. Pry until you notice the seam of the ear cushion separates from the plastic tabs.
  2. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • No replacement parts for these felt covers
    • Gently peel off the “L” and “R” felt covers with your fingers.
    • Note: These covers are glued in place and cannot be replaced—set them aside carefully.
    • Pro tip: Use minimal force to avoid tearing; you may need to re-glue them during reassembly.
  3. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7-millimeter silver screws from the inside by using the Phillips #000 screwdriver to disconnect the back cover.
  4. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5-millimeter silver screws attaching the earphones to the headband using the Phillips #000 screwdriver.
  5. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a metal spudger between the earpiece and the band joint.
    • Gently pry the joint outward until the earpiece slides free.
    • Note: A “metal spudger” is a flat, non-marring tool designed for leverage—use carefully to prevent damaging the plastic.
  6. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the silver cover on the outside of the headset using the spudger.
    • Pry until you hear a distinct pop; this indicates the cover has separated from its base.
  7. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Warning: This step requires soldering skills and precision. If you’re not experienced with soldering, seek assistance.
    • Heat the solder joints near the cable connector port using a soldering iron.
    • Simultaneously apply solder wick to absorb the molten solder and release the ribbon cable.
    • Once solder is cleared, gently lift and remove the ribbon cable using tweezers—avoid pulling directly on the cable.
  8. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the cable connector with spare driver/audio jack combo.
    • Optional: desolder the five audio jack posts seen here, and replace individual audio jack.
Congratulations — you’ve successfully replaced the audio jack on your Bose QuietComfort 35 II headphones
  • Before reassembly, compare all new and old parts to ensure compatibility.
  • Reattach components by carefully reversing each prior step:
    • Solder the ribbon cable and audio jack securely.
    • Reinstall the earpiece to the headband and fasten all screws.
    • Reposition the felt covers and reapply adhesive if needed.
    • Snap on the silver back cover and reinsert the cushion pad.
  • Finally, test audio functionality and mechanical fit before fully closing the headset.
kssexton
crwdns2935283:011/08/23crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2023 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S1G2
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 1,297
