Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement
  1. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement, Audio Jack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove the ear cushion pad. Pry gently until the seam separates from the plastic tabs.
  2. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • No replacement parts for these felt covers
    • Carefully peel off the “L” and “R” felt covers with your fingers.
    • Note: The covers are glued in place and cannot be replaced, so set them aside carefully.
    • Pro Tip: Use minimal force to avoid tearing; you may need to reattach them with adhesive during reassembly.
  3. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 7 mm silver screws from the inside and detach the back cover.
  4. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two 5 mm silver screws securing the earphones to the headband.
  5. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a metal spudger between the earpiece and the headband joint.
    • Insert the flat end of a metal spudger between the earpiece and the headband joint. Gently pry outward until the earpiece slides free.
    • Note: A metal spudger is a flat, non-marring tool designed for leverage. Use it carefully to avoid damaging the plastic.
  6. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to detach the silver cover on the outside of the headset.
    • Use a spudger to detach the silver cover on the outside of the headset. Pry gently until you hear a distinct pop, indicating the cover has separated from its base.
  7. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Warning:This step requires soldering skills and precision. If you are not experienced with soldering, seek assistance.
    • Use a soldering iron to heat the solder joints near the audio cable connector port.
    • Use a soldering iron to heat the solder joints near the audio cable connector port. At the same time, apply solder wick to absorb the molten solder and release the ribbon cable.
    • Use a soldering iron to heat the solder joints near the audio cable connector port. At the same time, apply solder wick to absorb the molten solder and release the ribbon cable. Once the solder is cleared, gently lift and remove the ribbon cable using tweezers—avoid pulling directly on the cable.
  8. Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose QuietComfort 35 II (Model 789564‑0010) Audio Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the replacement ribbon cable and audio jack assembly.
    • Optional: Desolder the five audio jack posts. Then, replace the individual audio jack with the new one.
Congratulations — you have successfully replaced the audio jack on your Bose QuietComfort 35 II headphones.
Before reassembly, compare the new and old parts to ensure compatibility. Reassemble your headphones by reversing the steps in the guide:
  1. Solder the ribbon cable and audio jack securely.
  2. Reinstall the earpiece on the headband and fasten all screws.
  3. Reposition the felt covers and reapply adhesive if needed.
  4. Snap on the silver back cover and reinsert the cushion pad.
  5. Test audio functionality and mechanical fit before fully closing the headset.
kssexton
crwdns2935283:011/08/23crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2023 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S1G2
crwdns2936753:030crwdne2936753:0 90
crwdns2942667:0crwdne2942667:0 1,789
