Bose Quiet Comfort 35 II Speaker Driver Replacement
  1. Bose Quiet Comfort 35 II Speaker Driver Replacement, Speaker Driver: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the ear cushion pad using the plastic opening tool on the right headphone.
    • This will be done using a prying motion between the cushion pad and the headphone itself.
  2. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take off the ear cover off by peeling the glue back with hands.
  3. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7-millimeter silver screws on the right earphone using the Phillips #000 to disconnect the back cover.
  4. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5-millimeter silver screws attaching the earphone to the headband using the Phillips #000.
  5. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the earpiece from the band to reach the speaker driver with better access.
    • This will be done with your hands. The connecting piece can slide out and allow it to detach.
  6. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the silver cover piece on the outside of the headset using the black stick spudger.
    • This will be done by entering the black stick spudger in an opening and pry the cover piece off.
  7. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 5-millimeter black screws using the Phillips #000 around the circuit board.
  8. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the gray on/off switch on the circuit board.
    • This can be done with your fingers. Just pull up on the switch and it should detach.
  9. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the glued ribbon cables with the black stick spudger by entering it below the ribbon cable and pulling it up.
    • This prying motion will allow the ribbon cable to come off safely.
  10. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the second ribbon wire for the charging cable with your hands by pulling each side of the component to separate it.
    • No extra tools are needed.
  11. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iOpener to loosen the glue on the speaker cover by laying it on top of the glue.
  12. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the speaker cover using the flathead from the Plastic Spudger Set.
    • Enter the flathead under the plastic speaker cover and pry in an upwards motion.
  13. Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Quiet Comfort 35 II Speaker Driver Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the two speaker wires off of their post.
    • Prior knowledge is needed for this step, it can be very hazardous.
    • You can now reach the speaker driver and replace it with a new part.
kssexton
crwdns2935283:011/08/23crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-2, Harley Fall 2023 crwdns2935289:0IUPUI, Team 1-2, Harley Fall 2023crwdne2935289:0
IUPUI-HARLEY-F23S1G2
Where can i buy the new speaker Driver ?
Kanikelll - crwdns2934203:0crwdne2934203:0
I bought it from ali express. Idk how fine it works tho. Came home in 5 days
Oye Paglu -
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 194
crwdns2942667:0crwdne2942667:0 3,190
