Sometimes Bose QuietComfort 35 II (Model:789564-0010) users complain about intermittent audio input when the audio jack cable is moved. This can be a sign of a bad audio jack. This guide details the removal and replacement of the stereo jack connector. If a new audio jack is added the following guide on soldering may be helpful:
Take off ear cushion pad using the plastic opening tool. Pry until you notice the seam of the ear cushion separates from the plastic tabs.
Remove the felt with the "R" and "L" symbols to uncover the electronic components inside by peeling it off with your hands.
Remove the two 7-millimeter silver screws from the inside by using the Phillips #000 screwdriver to disconnect the back cover.
Remove the two 5-millimeter silver screws attaching the earphones to the headband using the Phillips #000 screwdriver.
Detach the earpiece form the band using the flat part of the metal spudger.
Slide the joint at the end of the headphone band out to release ear piece.
Detach the silver cover on the outside of the headset using the spudger.
Solder off the ribbon cable from the driver near the cable connector port to detach it.
Replace the cable connector with spare driver/audio jack combo.
Optional: desolder the five audio jack posts seen here, and replace individual audio jack.
