Bose NC700 Battery Replacement
  1. Bose NC700 Battery Replacement, Remove the ear pad from the left cup: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic card to remove the ear pad from the left cup. Slide the card into the slot and make a rotating motion.
  2. Bose NC700 Battery Replacement, Remove the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fabric cover and remove the four screws using a Torx TR6 screwdriver.
  3. Bose NC700 Battery Replacement, Disconnect the cable and remove battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the flex cable.
    • Cut the three battery cables. Cut one wire at a time to avoid short circuits!
  4. Bose NC700 Battery Replacement, Remove battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is glued to the case. Use a knife to carefully cut off the battery. Take care not to damage the battery!
    • Be sure to clean any adhesive residue from the case.
  5. Bose NC700 Battery Replacement, Remove the shell from the battery.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the shell from the old battery.
  6. Bose NC700 Battery Replacement, Remove the controller from the old battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the controller from the old battery.
  7. Bose NC700 Battery Replacement, Remove the controller from the new battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the controller from the new battery.
  8. Bose NC700 Battery Replacement, Solder the new battery to the old controller: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bose NC700 Battery Replacement, Solder the new battery to the old controller: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bose NC700 Battery Replacement, Solder the new battery to the old controller: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Solder the new battery to the old controller. Observe the polarity!
  9. Bose NC700 Battery Replacement, Wake up the controller: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose NC700 Battery Replacement, Wake up the controller: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Measure the voltage at the controller pins. You will most likely get 0 volts. It is necessary to wake up the controller.
    • Use any battery controller. Solder the battery to the battery terminals on the controller.
    • Charge the battery through the external controller for 5-10 minutes.
    • Disconnect the charging cable and verify that the battery is energized. Charge the battery to 4 volts (if required).
    • Unsolder the external controller.
  10. Bose NC700 Battery Replacement, Attach the controller: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the controller to the battery with tape.
  11. Bose NC700 Battery Replacement, Solder the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the battery. Use heat shrink tubing or duct tape to insulate the soldering area.
    • Your headphones will turn on when you solder the battery. Turn off the headphones.
  12. Bose NC700 Battery Replacement, Place the battery in the bottom of the cup: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the battery in the bottom of the cup.
To reassemble the unit, follow the instructions in reverse order.
crwdns2935229:09crwdne2935229:0
crwdns2934873:0crwdne2934873:0
ru en
100%
crwdns2934883:0Andrew Yakunincrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Andrew Yakunin
crwdns2935283:002/17/24crwdne2935283:0
662 crwdns2915208:0crwdne2915208:0
crwdns2947412:020crwdne2947412:0
Thank you, very useful and money saving
Petra Ehlers - crwdns2934203:0crwdne2934203:0
Happy to help.
Andrew Yakunin -
Cool! how did you knew the battery was the issue? Did you have the red/white blinking LED issue on your headphones? I got that issue since the end of last year, and am not quite sure if it is a software or hardware related issue. Would love to fix it but indeed couldnt find any official replacement batteries or anything.
Headphone - crwdns2934203:0crwdne2934203:0
Yeah, I had the same problem. I think there's a bug in these headphones. If the battery is very low, the headphones think there is no battery and don't charge it.
Andrew Yakunin -
How many hours does this battery last on full charge?
Jonathan Ortiz - crwdns2934203:0crwdne2934203:0
I got about 15-17 hours at medium volume with the NC off.
Andrew Yakunin -
Be careful when replacing the battery!
The original seems to be a HV Lipo (3.8V).
Replacing it with a normal Lipo (3.7V) can lead to overcharging.
Rene - crwdns2934203:0crwdne2934203:0
You're right. But the battery is still working fine.
Andrew Yakunin -
Does anyone have a link to a replacement battery they’ve used? Thanks
Adam Law - crwdns2934203:0crwdne2934203:0
Saw a battery that is 3.8v. Do you think this will works?
https://www.aliexpress.com/item/10050060...
Loh Loh - crwdns2934203:0crwdne2934203:0
Another one, seem like this is the original battery.
https://www.joesge.com/products/bose-nc7...
Loh Loh -
I managed to fit a 102040 instead of 802040, which gave more capacity.
https://www.aliexpress.com/item/10050045...
And you do not have to cut the wires to the battery, but simply cut the connector on the battery, and solder the to metal flaps to the new battery, making the change a tiny bit easier
Thue Vestergaard Iversen - crwdns2934203:0crwdne2934203:0
Glad you got it. Do you have any photos?
Andrew Yakunin -
Hi there,
Did you try to fit bigger batteries into the frame?
Petr - crwdns2934203:0crwdne2934203:0
I've found a compatible battery from a company called "vhbw" which sells replacement batteries for all kinds of electronics - "NC 700" in this case.
That made things a lot easier because I didn't have to solder anything. I've just cut the cables to the old battery (one by one and then isolate them to prevent short circuits), removed it and tied together the corresponding cables with each other with smurf tube. Works like a charm. I've also had to load it via an external loading module first.
The issue I've had was the red and white blinking LED. This solved it, the earphones now accept power again and start loading.
Sebastian - crwdns2934203:0crwdne2934203:0
Hi, Thank you very much. I am so thankful for ppl like you who can show me how to do something as if I was in sixth grade. I managed to fix my headphones with you standing on my shoulder.
Brian
mortisgage - crwdns2934203:0crwdne2934203:0
Hi
I'm glad my guide helped you.
Andrew Yakunin -
I found a good fitting battery on amazon.de (Germany). You do not need to change the battery circuit board because it already has the three cables red, black and white. The battery is called BW889004009 (vendor vhbw) and is labeled as replacement for 792200-0010. It worked for me perfectly.
https://www.amazon.de/vhbw-kompatibel-Wi...
Stefan Watermann - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 168
crwdns2936753:030crwdne2936753:0 670
crwdns2942667:0crwdne2942667:0 10,238
