Bose doesn't sell batteries for the NC700 and doesn't seem to make replacements. I couldn't even find a Chinese equivalent. In this guide, I describe the process of replacing the original battery with a universal battery.
Please do not try this again unless you have a basic knowledge of electronics and have never soldered.
Use a plastic card to remove the ear pad from the left cup. Slide the card into the slot and make a rotating motion.
Remove the fabric cover and remove the four screws using a Torx TR6 screwdriver.
Carefully disconnect the flex cable.
Cut the three battery cables. Cut one wire at a time to avoid short circuits!
The battery is glued to the case. Use a knife to carefully cut off the battery. Take care not to damage the battery!
Be sure to clean any adhesive residue from the case.
Remove the shell from the old battery.
Cut the controller from the old battery.
Cut the controller from the new battery.
Solder the new battery to the old controller. Observe the polarity!
Measure the voltage at the controller pins. You will most likely get 0 volts. It is necessary to wake up the controller.
Use any battery controller. Solder the battery to the battery terminals on the controller.
Charge the battery through the external controller for 5-10 minutes.
Disconnect the charging cable and verify that the battery is energized. Charge the battery to 4 volts (if required).
Unsolder the external controller.
Attach the controller to the battery with tape.
Solder the battery. Use heat shrink tubing or duct tape to insulate the soldering area.
Your headphones will turn on when you solder the battery. Turn off the headphones.
Place the battery in the bottom of the cup.
To reassemble the unit, follow the instructions in reverse order.
crwdns2935229:011crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0Andrew Yakunincrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:024crwdne2947412:0
Thank you, very useful and money saving
Happy to help.
Cool! how did you knew the battery was the issue? Did you have the red/white blinking LED issue on your headphones? I got that issue since the end of last year, and am not quite sure if it is a software or hardware related issue. Would love to fix it but indeed couldnt find any official replacement batteries or anything.
Yeah, I had the same problem. I think there's a bug in these headphones. If the battery is very low, the headphones think there is no battery and don't charge it.
my man. thanks
