Bose Ae2w 2.5 Audio Jack Replacement
  1. Bose Ae2w 2.5 Audio Jack Replacement, Earpiece Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement, Earpiece Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the cushions away from the sides of the headphones, sliding the cushions out from under the notches.
  2. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully wipe the inside of the earpiece clean. This can be done with a moistened cotton swab or alcohol wipes.
  3. Bose Ae2w 2.5 Audio Jack Replacement, Speaker Mesh: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement, Speaker Mesh: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger or tweezers, carefully lift the speaker mesh from around the edge.
    • The mesh is typically glued down, go slowly to avoid tearing or damaging the speaker beneath.
    • Cut your new mesh slightly larger than the opening so it can be anchored around the edges.
  4. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Scrape off any gunk or adhesive left over on the ear cups.
    • Use a moist cotton swab or alcohol wipe to ensure the surface is completely cleaned and ready for new adhesive.
  5. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a thin layer of fabric glue or double-sided tape around the perimeter of the speaker housing.
  6. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently place the new mesh over the speaker opening, pressing it down onto the adhesive.
    • Wait for adhesive to dry if applicable.
  7. Bose Ae2w 2.5 Audio Jack Replacement, 2.5 Audio Jack: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement, 2.5 Audio Jack: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the cushion and mesh are removed, remove the three screws in the earpiece.
  8. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the earpiece to access the audio jack.
    • Remove the two screws holding it in place.
    • Lift and remove the audio jack assembly.
  9. Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bose Ae2w 2.5 Audio Jack Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify all solder connections on the audio jack circuit board.
    • Using your soldering iron, carefully desolder each wire from the circuit board.
    • Take care not to damage any of the wires, as they must be soldered onto the new replacement audio jack circuit board.
Ben Ponte
crwdns2935283:003/24/25crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-4, Biswokarma Spring 2025 crwdns2935289:0UMass Dartmouth, Team 5-4, Biswokarma Spring 2025crwdne2935289:0
UMASSD-BISWOKARMA-S25S5G4
crwdns2942667:0crwdne2942667:0 117
