Your plug is damaged on your Bosch PMF 180 E? With this guide, you can exchange it!
Loosen 9 screws (combination screw T20 / slot # 5)
With a flat object, the housing can now be easily opened along the seam. For example, with Jimmy, which is shown here. It also works with a flat knife or a thin Japan spatula.
The housing is now open and further steps can be taken.
If necessary can now be cleaned. (in this picture you can see that it is obviously necessary)
Do not remove the grease! The drive needs that. Of course, it can also be replaced by a new one.
Now first loosen the two slotted screws # 3 so that the wires can be pulled out of the clamp.
Pull the wires out of the holder with a gripping tool. For example, with a pair of tweezers or a small, flat pair of pliers.
Now loosen the two screws (T20 / slot # 5) of the cable lock and remove the clamp.
The cable can now be pulled out of the grommet and replaced
Repeat the steps in order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0irlandacrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2935103:0crwdne2935103:0
crwdns2917034:0crwdne2917034:0
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
