Bosch Maxx WFL2455 Washing-Machine Front panel disassembly
  1. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Lower cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Lower cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your device.
    • Remove the cover hiding the drain hole.
    • Remove the T20 Torx screw which is holding the lower cover.
    • Remove the lower cover by sliding it to the right.
  2. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Detergent dispenser: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the detergent dispenser by opening it then by pressing on the notch with your finger.
  3. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket ring: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket ring: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ring holding the drum gasket.
    • Start with the spring located near the window hinge.
    • Avoid using sharp or cutting tools to avoid damaging the gasket.
  4. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Drum gasket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Bring the entire gasket over the edge it is placed on.
    • When reassembling, you will need to be a little careful to put the seal back on its edge.
    • Move the gasket to the inside of the drum so that it won't bother when you'll be removing the front panel.
  5. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel mounting screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel mounting screws: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T20 Torx screws located below the front panel.
    • Remove the T20 Torx screw located in the detergent dispenser slot.
  6. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Removing the front panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Removing the front panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front panel is held in place by a strip, held by the previously removed screw of the detergent dispenser slot.
    • To remove the front panel, start by sliding it downwards (it should normally fall under its own weight).
    • Positioning lugs hold the front panel on each side. Once the panel has been slid down, tilt it forward so that it can be removed.
    • The positioning lugs remain attached to the front panel once it is removed.
    • Electrical connections connect the front panel to the rest of the device (see next step).
  7. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel's connections: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Front panel's connections: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There's an electrical connection between the body of the device and the front panel (probably a window sensor).
    • Disconnect the window sensor by lifting the connector's tab and by pulling it down firmy.
    • On the second picture, the connector is shown partially disconnected.
  8. Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bosch Maxx WFL2455 Washing-Machine Front panel disassembly, Wire guide: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the guide from the front panel.
    • And voila, the front panel is disassembled!
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Haitham
crwdns2935283:012/04/09crwdne2935283:0
359 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 128
crwdns2936753:030crwdne2936753:0 499
crwdns2942667:0crwdne2942667:0 19,386
