Bosch MFQ 36440 Disassembly
  1. Bosch MFQ 36440 Disassembly, Remove screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 2x Torx screws (size 10) on the front
  2. Bosch MFQ 36440 Disassembly, Remove the grey front cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch MFQ 36440 Disassembly, Remove the grey front cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the front cover
    • Gently push downwards the cover, then pull it through the holes
    • Once it is detached at the top, slide the entire gray cover down
  3. Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bosch MFQ 36440 Disassembly, Detach the two sides of the mixer's white case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The first step is somewhat tricky. Use a long screwdriver to release the first part at the top.
    • Continue your way all around the case.
    • The clip on top front is tricky a long and thin flat screwdriver is needed
    • The clip on very top is impossible to release you need to pry the two half’s carefully apart until the top releases
  4. Bosch MFQ 36440 Disassembly, Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Bosch MFQ 36440 Disassembly, Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Prop everything back into the half without the clips
    • Take care about the safety cam to be aligned in the cover
Stanky
crwdns2935283:007/08/17crwdne2935283:0
1,268 crwdns2915208:0crwdne2915208:0
Hey, so what does “Continue your way all around the case” mean? I got the one clip open which you pictured, and then I got the case open just a tiny bit more, but now I’m stuck.
Could someone perhaps detail the last steps more? :(
Carsten Hagemann - crwdns2934203:0crwdne2934203:0
When you put it together again use the side with the cable “channels”, it is way easier than with the other side.
Tobias Vdb - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 9,098
