Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug
  1. Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Remove the bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Remove the bottom: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Remove the bottom: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the jug upside down
    • The black base is screwed into the housing. Unscrew to the left.
    • Reach into the jug while wearing a glove
    • Turn the jug upside down and carefully remove the glass body and place it with the opening on a soft surface. The fused nozzle used for pumping can break off easily.
    • The glass body is available as a spare part (part 00441154, approx. 22 EUR incl. seal)
  2. Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Removal of the upper body: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Removal of the upper body: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Removal of the upper body: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The seal is loosely inserted in the housing. It is usually the cause for to leak out of the thermos housing.
    • The seal is available as a spare part (00426033, approx. 5 EUR).
    • For further disassembly loosen the 3 Torx T10 screws (plastic thread ca 3.2 x 15)
    • Press on the black plastic point and pull apart the upper and lower part
  3. Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Remove the handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The handle is attached to the housing with a PH2 screw.
    • If the handle is loose, tighten carefully so that the thread in the plastic does not tear out. The handle is not available as a spare part.
  4. Bosch DisassembleTKA8SL1 Solitaire coffee maker thermos jug, Reassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Thoroughly clean or replace the gasket before reassembly.
    • Use a piece of foam between the base and the glass container to apply a little more pressure to the seal, without damaging the glass container
Follow these steps in revere order to reassemble your device
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
HowThingsWork
crwdns2935283:007/21/21crwdne2935283:0
3.180 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,697
