Boosted Board 1st Generation Skateboard Bearings Replacement
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Boosted Board 1st Generation Skateboard Bearings Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
To reassemble your device, follow these directions in reverse order.
Emily Imfeld
crwdns2935283:010/06/16crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-7, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 15-7, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S15G7
crwdns2942667:0crwdne2942667:0 846
